smolkin
Stuck inside Mobile
Well, like the title says, for the past couple of days my old no-idle issue has returned. After revving up it just stalls, it will not return to a nice idle. When you initially depress the accelerator, it hesitates for several seconds, then revs on up OK; let off and it stalls. It likes to do this when I'm stopping and turning, especially if there's oncoming traffic. Bottom line: If I can't fix this, I have to get another vehicle. It is going to get me killed.
I am at my wit's end. Today in desperation, I installed a clear return line at the filter head...I am getting alot of foamy bubbles. A WHOLE LOT. So I bypassed the FSV and the Vegtherm loop. Still the same. I traced all the fuel lines from the rear tank (only one I use anyway) and they are all OK. The Vormax and its associated lines are OK. The lift pump is 3 months old, lines are OK. The IP is 1 year old. The hard lines got new olives when I put the IP on. I put a new fuel filter on today (to rule that out). What else can it be?!? The only thing I haven't checked is the tank pickup (OEM and tank is currently FULL) and my injectors and returns are old but not visibly leaking. Do I need to drop the tank this weekend, is there anything else I can check?
