Glow plugs aren't working again. Same as last week, I get a split second of the wait to start light then just the after glow clicks. Truck doesn't start. This thing has never started more than once in a row since I've known it.
I checked the hacked plug on the intake, it wasn't grounding (or was bad). So I replaced all the plugs with my Motorcraft ones (except the one under the turbo). Test light will light up on the one in the intake.
Made zero difference.
If I bypass the controller by grounding the white wire, should I hear the relay click? Am I misunderstanding how the manual switch is wired in?
Also noticed, and not sure if it's new, the temp gauge will go all the way to hot while the key is in the on position. IS that telling the GPC I don't need the plugs?
Tim.
Tim.
