LUCKY_LARUE60
OK, I'm totaly confussed
Amen, that's alot of info for one time. So basically what y'all are saying is, it isn't the original trans, unless someone at Ford got liquored up on their break, but it could be, but more likely not? Did I catch that right., this site is awesome. Most likely if I can find a 5 sp. I want to put it in the truck anyway. Are there any stock 5 sp. that will hold up behind a diesel usually pulling a 18' stock trailer with 5,000#'s of horses on? Are they a direct bolt in or are modifications necessary?
Well you brought up the third 4 speed option, the NP435. From what I can see, the NP is only available with smallblock 2wd or smallblock 4wd with a divorced transfer case.
"You can recognize the NP435 by it's single piece, aluminum, bolt-on top cover with the shifter sticking directly out of the top and a fitting on the driver's side for the back up light switch. Most have the letters "NP" inside a circle cast into the cover. The NP435 is sometimes hard to tell from the similar looking T18 or T19. One way to check is with a magnet, which won't stick to the aluminum top cover of the NP435. The NP435 also has the PTO cover plate on the passenger's side. Weight is approximately 120 lbs."
The T-18 (non syncro first/reverse) and T-19 (syncro first/reverse) share the same ratios. There isn't a syncro non creeper used with anything other than a 302 (SROD/TOD) in a truck.
So I suggest you ignore the missinfo from "another site", and settle in for the straight info here![]()
Adrianspeeder
