84TD
History is I bought this trans of craigslist from a dead guy at an estate sale. He was rebuilding a 93 F250 and had "rebuilt" the trans and was in the process of rebuilding the engine when he had a heart attack.
The Problem- There is actually a vibration through out the rpm band but it is REALLY bad at idle. It vibrates the entire truck. If you ever been in a 80's vw with bad motor mounts at idle, its just like that. Just super vibraty.
So its either in the flywheel or trans. The flywheel is a LFW127 and I am not sure about the clutch setup because I got it with the trans but it is also a LUK.
For those that have rebuilt a ZF: During the rebuild of a ZF is there a counter shaft or anything you could hose up to cause a vibration?
I am starting my research...... this blows.
