f350goatee
- Joined
- Nov 19, 2007
- Posts
- 3
- Reaction score
- 0
Been lurking for a while and just thought I'd introduce! I'm in the high desert(Victorville, Ca) area, have a recently purchased 93 f350 cc turbo idi, bone stock besides the cut-off muffler(if you want to call that an upgrade)had the fuel filter, return lines,o-rings,alignment,coolant and hoses replaced along with an oil change(about 1700 bucks at a local shop here, I know i got ripped, but that was before I knew about this and other forums!)The truck has 127000 mi. on it and runs pretty good for all I know. Just advanced the timing (white smoke at idle) didn't stop the smoke( air in system?)but she seems to run better!I have a pyrometer and the temps are about 6-700 when running about 2300rpm at about 70mph which is a little higher than I used to see before advancing the timing.So anyway...Hello fellow idi'rs!Hope to learn a lot from all of you!!!
