ISPKI
Hey all,
So I got this 94 Superduty 7.3 NA. Truck was fairly well maintained, has 200k on it. Looks like they put a fair amount of new OEM parts into it.
I'm working thru alot of the usual items, injector O rings have been replaced, caps no longer leak. Replaced the fluids, oil filter, fuel filter, batteries etc.
Truck takes a while to start. Seems like air intrusion or GPs maybe. The GPs cycle only for a couple seconds even when it's pretty cold and then start clicking on and off. My old truck never did that clicking thing so not sure what that is. The connectors in the GP harness are all crumbled. I can get the truck to start if I hook up my charger to it at 250amps but takes a solid 45 seconds to a minute of intermittent cranking. When I hit the shrader valve on the filter head it spits a tiny bit of air.
Going to pull a few of the GPs next and see what they look like. Anything else I should be checking? Maybe I should replace the fuel return lines and caps while I'm at it.
