MTKirk
I just installed a rebuilt Injection pump on my '87 6.9, timed it to 8.5 btdc using a ferret meter, cold advance is working correctly. Truck runs fantastic, maybe better than it ever has, BUT; I'm hearing a knock from the rear driver's side bank of cylinders, I hear it at idle and it goes away around 1200rpm. This noise wasn't there with the old pump. The old pump had major issues; fuel pressure dropped out frequently (as it would return excessive fuel most of the time), timing wandered 4 or 5 degrees seemingly randomly. There was however, no knock like I am hearing now. I have a theory that my new pump is pushing fuel harder than the old one and causing an injector (old, unknown history) to pop a little early causing the knock, seem reasonable? Thoughts?
