shakenbake254
I bought a 1986 f250 6.9 recently to restore it and the next thing on my list is new fuel lines going from the duel tanks to the sender(where the 4 lines go to 2). The guy I bought it from had the rear lines hooked up to the front tank and the front lines unhooked. After hooking the lines up properly and running the truck from the front tank I noticed the truck was idling really rough, surging, and eventually dying. My guess is air intrusion on the front tanks fuel lines. My question is should I look for metal lines, nylon, or rubber diesel rated lines? Right now it has nylon lines with plastic push style fittings. Should I get metal fittings with the new hose line or reuse the plastic ones? any help is appreciated. Thanks.
