New Battery Time
I need a set of batteries for my truck. I was thinking about some Interstate batteries around 1000 or 1100 amps each. Does anybody have a size or number for such a battery? If not what do you run and how do they work for you... Thanks.
metrojd
Pittsburgh,Pa
Batterys
I run Walmart Yellow I think they are
They are Everstart 1000CA and 850CCA
I have ran these for years and no problems.
They are 3 year free replacement and only $60.00 or so
For the $$ I dont think you can beat them.
I ran these in all my plow trucks for years with no problem
Diesel JD
Gainesville, FL
I would get either Interstate MTP65 with 850CCA each or the sealed gel cells at 1000CCA plus from CAT or Interstate. If you go Interstae, see if you can get a "blem" battery, they still have a new battery warranty and are on heck of a lot cheaper than a pretty one. I got one in the 650-750CCA range for my boat for around 35 and one for my parents 4Runner at around 38.00 at the Interstate shop.
gandalf
Senior Member
CA &/or Maine
I've recently seen the equivalent at Costco in their Kirkland house brand. 1000CA and 850CCA, for right around the same price. I think either one will be hard to beat if you calculate cost per year.
lotzagoodstuff
Carmel, IN
Optima's in an IDI?
I know they are expensive, but has anybody used Optima's in IDI applications? I have one in my race car that's 5 years old (it gets lots of charges as it has no alternator) and a freind of mine has one that he got in a wrecked salvage car that he brought back to life three years ago and it still going like an Energizer bunny. I laughed at him when he was trying to bring it back to life but now he's laughing at me.
RLDSL
Diesel fuel abuser
Arkansas
I picked up a pair of group 31 commercial truck batteries at Truck Pro last year for about $63 each. 1190 cranking amps, 1000 cold cranking amps at 0 deg f, 185 reserve capacity.
Those suckers really spin the engine over ;Sweet
I had to move the battery trays inward away from the fenders by adding some spacers between the tray and the fender to squeeze them in.
I had looked at the Optima yellow top commercial batteries at the time, but they were just a bit too tall, and I would have had to move the trays down to keep the posts from hitting the hood ( zzzzaaaaappppp :D
The red top optimas have the amps, but not enough reserve capacity for an engine this size
------Robert
IDIJunkie
Milan, IN
I have 2 new optima blue top batteries to put in the truck when it's all back together. I will let everyone know how they start the truck later.
Exekiel69
I have a diehard on one of My work trucks and it is running fr the 5th year now, went to check it and it was still OK.:thumbsup: It starts the engine every day.
MIDNIGHT RIDER
TIME FOR BATTERIES ??
If you haven't already done so, now would be a good time to throw away those troublesome lead battery cable ends and replace them with copper-lug ring-terminals.
Replace the batteries with Group 30S or Group 31S real stud-terminal batteries; you will be happy you did, as life is much easier with stud type batteries.
If you don't have time to be swapping cable-ends, you can still buy the stud-terminal batteries and use the post-style screw-on adapters with your existing cable-ends; this way, you will already have the stud-terminal batteries when you get ready to do the cables.
oregon-mike
Eugene, OR
I have a pair of Costco (Kirkland) 1,150/1000 CCA batteries that I put in mine when I bought it back in Feb. I think I was out of there for under $120 for the pair.
MadScientist
