zukgod
Hello all I have lurked for some time here and have learned a ton thank you. But now I have a question that I have searched and can not find the answer to. I have a 1990 7.3idi in a 4x4 truck. The started went out, and not having a diesel before other than the tractor, I tapped on the little regulator on the passenger fender well and even started it that way a couple times. Now when I installed the stater like an idiot I did not disconect the batteries, and had one and only one small arc. Now the truck is almost imposible to start cold. Once warm she fires right off.
I have noticed that before installing the starter when everything worked fine,when I would start it there would be the glow plug click for a bit while the truck warmed up, now I don't have that. I checked the glow plugs with a light and they all seemed to work fine. When I turn the key it still says wait to start like they are working, but something is wrong. Any help would be much appreciated. This site has helped me solve a ton of other problems already.
