Need help
Farmer Dill
Ohio
Back lights and brake lights and turn signals won't come on when the lights are own but when there off all three work?
Cincinnati Guy
Cincinnati, Ohio
Check the headlight dimmer switch on the floor. When I had the truck the headlights would sometimes go off when I hit a bump, so I replaced the dimmer switch and the problem went away, that or you got a losse connection there.
Farmer Dill
Ohio
So that dimmer switch would cause the rear lights not to work with the headlights on?
f-two-fiddy
Duluth, Mn.
Not likely.
Check the wiring out back. I'd almost guarantee that someone has the wiring all hacked up with those stupid scotch lock wire taps.
