need dana 50 or 60 hub for a 93 ford
1mouse3
il
I kinda ran into a bind, something happened and now my wheel hub is trash. There aint no f250 or f350 of the year range needed for this part to be found in any salvage yard near st louis, craigslist has non and have no account to check facebook. This is the state of the hub I pulled off and there is no fixing what what went wrong.
This is the cheapest option Im finding new and not sure on any the expensive used ones to be found on ebay. Is there anyone close that has one these used laying around or know of a new one less thats less than $180?
dana 60 hub
IDIBOBS
Southern California
my oriellys shows 130 for hub and rotor with a life time warranty Parts geek (I hate ordering only) also says 130 for rotor and hub. Usually rock auto is much cheaper but shipping might kill you.
1mouse3
il
This is all I see come up for oriellys and is why too expensive
dana 50/60 hub
Rockauto only shows stock of one for the dana 44, where the one I need is out of stock. Parts geek dose not pull up any 4wd hubs.
dana 44 hub
dana 50/60 hub
Can also try www.car-part.com for used
That is helpfull and found some used at a good cost, but nearest is 4hrs away in springfield or kansas city MO
Been digging to see what can be found on ebay, found this that would also give a replacement rotor for the warped one I have now as well. It is more than want to spend on used but says its a 2-4 day shipping from TN, so went with this.
used hub with locker and rotor
1mouse3
il
Freight quote? (Most of these are NOT u-pick yards)
4hrs freight is probably quicker than eBay.
Sorry that Im rushing and should not, I did not see that the first time I look at that site and will remember that the next time I need a part for this now rare truck. The I one with ebay is all ready getting package for shipping with fedex, so there is good chance of 2 days on that one but the day freight could had been better.
1mouse3
il
Well fedex did its part and did better than 2 day, the shipper on the other took it time. Ether way got the part and got it installed, also puled the spindle to replace its bearing as well.
Found why it failed to stay tight, there is supposed to be a location pin but the old went hiding. This is the first Ive pulled that nut since I put the on year ago, never saw it only pulling the outer one.
This silver is not the one lasted used, but you would only know if you can look at both side. It made me clean the rim and tried again at cleaning the white wall,
