fields_mj
Anyone know where I can find a new rear hub? I've got a '93 3/4 ton with a fully floated rear end (A little over 6000 #). The rear breaks were completely shot. Had the mechanic put new ones in. In the process, he snapped 5 of the 8 bolts off that hold the cover on the hub on the drivers side. Apparently the bolts had loosened up and burgered up the threads on the hub side. They snapped off down inside the hub (yah!). I'm going to go pick the hub up in a little bit and see if I can't get the bolt holes located on my bridgeport so that I can drill what's left of the bolts out and clean the threads up for them. The only bright side is that the mechanic was the last one to have the hub/axle appart 3 years ago. If I'm not able to get it cleaned out, I'll need to replace the hub. Mechanic checked with everyone around here, and nobody has one.
....."Miracle rods" are what I call them...
