I picked up this truck two days ago. I'ts a 94 with a factory turbo. I have a few questions.
1) I am in the process of cleaning it up and freshening up some fluids. I picked up some Fleet charge, I drained the radiator and poped out both block drains. While the drains are out I am going to swap in the 1/4 npt petcock valves that a few people have mentioned here. So my question about this is that all I need to do before adding the new coolant/water? It had standard green anti freeze in in before, and I want to give it a fres start on the Fleet charge. If it still needs to be flushed out more where do I add the water? Heater hose?
2) I also want to add a coolant filter while I am doing all of this. Do you guys have pictures of where you normally add yours? Do you normally splice into a heater hose?
3) I am also wondering if there are any intake mods that you can do on the factory turbo (other than intercooler) that will add power? I want going to put an open element filter on it but after looking at it more the factory set up looks pretty efficient.
Can you guys help me out? Thanks for any help.
why swap to non turbo injectors?
