my new 1994 factory turbo
cardana24
Virginia
Typ4 is Russ. He is a member here from oregon. Really a great guy too. Knows plenty about thes trucks and motor too. I think he knows more about turbos than anyone on this forum. He can rebuild or upgrade many differant makes. PM him any questions... Install a set of BB code injectors. They will outperform the G codes all day long...
What model and years did the BB code injectors come on? Do they require any modification?
dansvan
My research has found that BB injectors no longer exist as a seperate
individual injector. There are either turbo or non-turbo injectors. Comments?
cardana24
Virginia
I have a question about my oil fiter and capacities. I was under the impression that the Motorcraft FL1995 was the powerstroke oil filter. But according to summit the filter that my truck (1994 factory turbo) calls for is the same one FL1995. When using the FL1995 filter how many quarts of oil should my truck hold?
Where can I get a repair manual for this truck? Most everything I have seen in the parts stores is for gas trucks.
Buy the BB code injectors from Mel or Russ. The BB code injectors are available thru many places. Just don't use the turbo "G" codes because they are for emissions issues and wont be a great as the BB injectors. I have tried both and will only use the BB codes... The 1995 filter is what most use. Usually 10 quarts qith the samll filters or 11 quarts with the large 1995 filter.
