jam0o0
ok so i thought i should show yall the info and ideas with the turbo elbo.
measure twice, cut once. i put the elbow, outlet down, on a table and set a sharpy on an altoids box. then turned the elbow, keeping it flat on the table, to get the cut line just right all the way around.
that thing is tiny no wonder these trucks are slow
the elbow is big enough here.i'll do some porting after i get the new v-band end welded on. the weld should give me the space to get a full 3" id.
the turbo outlet size.
new v-band
for comparison.
i'll put the welding info in the next post.
i didn't want the power stroke exhaust getting in the way when i put my 4 link and air bags on this truck. if i ever get around to that. so i had it end sooner. i used half the kit's tail pipe. the rest of it got sold or used for the new intake pipe.
i moved the muffler mounting bracket forward one crossmember. i drilled a few holes and trimmed the bracket to fit around the carrier bearing.
new v-band
for comparison.
