Moving Batteries
Late_99_psd
Taneytown, MD
Its an OBS body style. I have no idea what size batts they are, but I think they are somewhere around 800 cca's :dunno:
If I were to go through the effort of moving them, I think if I had the space, I'd frame mount them on the passenger side behind the cab. Getting that weight off of the front clip would make the front end a bit happier.
Yes yes Mel, I was thinking right behind the forward cab body mount area, two group 31 Yellow Optimas then re-ware the solenoid for the starter down to that area,cookoo and voila, NICE SHORT leads to the starter! Moocho cranking power!:sly:sly Also keeps the weight lower better centre of gravity! ya so maybe...hmm...wheels turning now :rotflmao
88beast
pa
shut up mel youre ruining my plans to put zombie killing bumpers on all the idis lol no point to weight reduction when you got a 600 plus pound front bumper lol
i put mine on the drivers side im really special
the long run to the starter relay in stock location aint bad at all i moved them to fit the turbo on the pass manifold
idiabuse
Princeton Fl
passenger side bed behind the cab, one Odessey 2150 does the job of two for me
Javier
88beast
pa
that came with the tray its now metal with all thread holding it down and they dont budge
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
Find a older ford or chevy van with a diesel. They have 1 battery down on the frame in a nice little box
lotzagoodstuff
Carmel, IN
Sounds cool: got any pics? I really want my batteries out from under the hood, or at the very least on one side of the engine bay.
93cc7.3
needs turbo power
plainfield IN
i am going to throw them both down there heck a 2 foot piece of 0 gauge to the starter would really be awesome to
rjjp
Needs to go test
Clare, Mi
I want to put two on each side, but then again I'm just weird.
RLDSL
Diesel fuel abuser
Arkansas
800cca in a small case with a small reserve capacity is tempting fate for a no start on a cold morning. It's not the CCA that gets you started with a diesel, it's the reserve capacity, that's why you see so many different batts that can be rated with the same CCA output, but the reserve capacity ratings will be all over the map depending on the case size. A high CCA gets you a quick burst that peters out quickly, a high reserve capacity is what gets you the extended cranking needed to get an ornery diesel to fire on a cold morning. This is where a pair of group 31s batts really shine, you can grind those babies down if needed . It's mighty nice having 1150 cca ea along with a high reserve capacity. REmote frame mounts are pretty good setups, just remember rock guards or your high output batts turn into no output batts.
