Looks like I'll be in good shape. I checked the online catalog for advance and their new replacements for the early ones are metal, so I'm grabbing one, well I suppose I should replace the set
THanks
check the cables...whats happens is,,,the cables DONT stretch..............the "fork" that moves the pin,just inside where the handle is,spreads over a period of time...why?? because ford in their infinite wisdummmm,didnt put any lube on that pivot point!!!! hence the spreading of the fork from binding!! you can squeeze the "fork" back together..........also..the spot where the cable hooks behind the fork, will wear also....SOMETIMES, the ball will break off the end of the cable also....real fun!!!!! and where this whole assm bolts into the door..likes to break!!!! not one of fords better ideas!!!
