Max safe sustainable RPM
The_Josh_Bear
Western WA
It's not much fun on your ears, but you can run these engines against the governor if you like, all day long. They are designed to do that in service, especially at stock power levels. When boosted it's actually safer to keep the RPM's up rather than down. Easier on the rods. Not saying you have to run a turbo engine up against the governor but use the whole power band and don't worry a bit.
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
Hey, that's my line! It's copyrighted, you owe me $3.
Now wait just a minute! While that is your line, IDIBRONCO isn’t a Dodge guy… u2slow and I are… but u2slow has Cummins powered Dodges, so he would just have your $3 Cummins-Dodge guy tax… but, I have a Dodge with a Dodge engine in it, which is a double whammy, so double tax. I owe you 6 bucks for IDIBRONCO’s use of your line. :rotflmao :joker:;Poke
Black dawg
sw mt
My calculator with 235 85 16 and 4.10 shows
2700rpm in zf 5th, and 3500 in 4th.
Same truck with 3.55 shows
2400 in 5th and 3000 in 4th.
All at 80mph.
I finally have my truck geared at 3.55, after owning it since 02. My hearing would be better if i did this a few hundred thousand ago.....
Towing power as far as accelerating is slightly less, but i can pull faster now and mpg is up significantly.
Cant Write
Placerville CO
That height should get you right back to the 3.55 gearing you left :rotflmao
You’ll need a step ladder to reach the bed and get in it!! Man this just fits you!! Cant wait to see how yours turns out, and likes 80 ;Poke;Poke:rotflmao
My van likes 72 with 30” tires, 4.10’s and an E4OD. It’ll run 80, but it likes 72.
KansasIDI
Wilsey, KS
That truck is just too tall…
Cant Write
Placerville CO
Oh I knew that, I was just pulling your leg. As you were wondering about 80 mph with 4.10 gearing and a ZF. So I figured bigger tires will get you back to the overall ratio.
I’m a stock height guy with 33’s. Skinny 33’s.
KansasIDI
Wilsey, KS
Skinny 33’s are my favorite too.
This truck will have stock ride height for a ‘95 Dana 60 F350 dually after this… minty mint…
Rdnck84_03
Kansas
I love the ride height of my 97 f350 C&C dually, absolutely hate the fuel mileage with 4.10 gears. I'm running the factory 235/75's. I'm sure that it will be similar on an idi.
James
Cant Write
Placerville CO
You’re going flatbed too right?
What about finding a 2wd 3.55 geared IDI to be your 80 mph rig, and your “about to be dually” as your heavy work rig?
KansasIDI
Wilsey, KS
Well, problem is, usually I need all my stuff, and I never have a plan for the day, I might know where I’m going in the morning, but might change at any moment. It’s all gotta be one truck. Has to be multipurpose… jack of all trades, master of none…
My Dodge just don’t quite cut it. It’s a regular cab… if it was an extended cab I might never have ventured into IDIs…
Regearing those axles is an option… might just be best to have 3.73s
I don’t need duals, but I am certainly fine with them.
Service bed ultimately. Will have to modify for pulling goosenecks…
Alleycat
