Manual GP glow time
jayro88
Auburn IN
I found this in some Ford service information. It appears to me the right column is the appropriate times the glow plugs can be on at a particular temperature. Of course, you would only want them on as long as needed to get the engine running.
That is great info. Thanks
jayro88
Auburn IN
Lotta good info so far; I've got the regular controller, but did splice the ground to a momentary switch under the steering wheel; just in case I need to do it manually. Another option is one of the more reputable gear reduction starters. Another option I think is fairly good, are the newer flat pancake heaters you glue directly to the bottom of the oil pan. Plug'er in for an hour, or 2, and your oil is warmed; no harsh starting.
Thanks. I have updated the rest of the starting system too. Turns over well.
I have my block heater that I put on a timer in the winter so it kicks on 2-3 hours before I leave in the morning.
Works well.
truckonfire
