Well these are all good points, and one of these days I'm going to take the time to do a comprehensive glow plug video so that people will actually be able to properly diagnose and fix these things. I fix these things all the time, not just on one truck, but dozens. Case in point, I have a 94 IDI Factory turbo customer who does snow removal. He couldn't get his truck to start last Friday night after I was closed, so he called another shop. He got the truck to them, and they put 8 brand new Autolite glow plugs, and a new $185 glow plug controller in it. The customer brought the truck to me yesterday morning, because... it still won't start. I fixed it by putting 8 Beru plugs in it, and fixing the broken wire going to the #5 and #7 (under the turbo) cylinders. What clued me in was the electrical tape. The other mechanic just twisted the wires together and put tape on them. Jobs like that require solder and heat shrink. I totally removed that part of the glow plug harness and rebuilt those two cylinder feeds, using the proper tools and materials. Now it works like a champ. What failed the other mechanic was A) - His inability to understand the relationship between the glow plug controller and the load that it controls, B) - His shoddy worksmanship, thinking that glow plug wires must work like trailer lights, and C) - His unfamiliarity with the IDI in general and absence on these forums. 3 of the brand new Autolite glow plugs were already burned out! Pretty amazing, considering the repair was just a few days old. In all likelyhood, there was never anything wrong with the customers original glow plug controller, and its hard to tell with these aftermarket ones, if they have bar or disc type contactors (you guys call them relays) on them. Now that the original controller is gone, its hard to say how long that GPC is going to last. I've educated the customer and returned all 8 Autolites to him. This is the kind of thing I see all the time, and it is always something simple that just isn't that hard to fix. As to what to do when it doesn't work as intended, and you are stranded somewhere without a block heater? Simple. Get out a pair of jumper cables, and use just one of the clamps to short together the two big poles on the contactor to manually energize the glow plugs that still remain operational. Want to avoid warm start glow plug operation? Find an ambient air thermostat like you would use on a furnace, and route the power feed or ground wire to the GPC through it. As long as the thermostat is warm, the glow plugs won't come on.
