main 12V+ on alternator and glow plug controller- wiring routing.
i was going to run 8 gauge wiring from the alternator to the main 12V feed on the starter thats 0/1 gauge.
and another to the glow plug controller.
do any of you see an issue with routing wiring this way?
besides the abundance of connectors on the starter...
DaveBen
Ukiah, Ca
I see that you are running multiple heavy gauge wires down to the starter. You really don't have a need to run that many high current wires down there. You can make a hot point on the fender and run the heavy wires there. You will be saving many head aches by doing this. :)
im trying to keep them hidden.
ive done this on many many gassers without an issue.(minus the GPC)
this is my first custom diesel... but not the last :D
no mufflers
rhode island
as long as the wires are properly sized and the connections are good I don't see a problem. I think on mine the main power wire goes to the starter and a wire goes from the starter to the relay on fender and the alt and GP connect to that.
Shawn MacAnanny
Delaware
8 gauge doesnt seem very heavy. I run 2 gauge plus the factory wire from my alternator but its a 250amp. But running to the starter shouldnt matter, that's a good idea to keep them i hidden.
