I prolly have at least 6 customers with IDI's and the LUK kit installed. I've seen enough issues with the kits over the years where I am still running DMF systems. Here's my latest finding. A little background first.
The truck is a 1990 F450 flatbed car carrier. It's tare is 11k, max legal is 15k but frequently sees 14-17k and infrequently sees 19-21k gross. 7.3 natural, 5.13 ration Dana 80 rear. It got a rebuilt ZF5 two years ago and the clutch disc was replaced then. The ZF5 required replacement of the input shaft and countershaft due to excessive wear on the gear teeth. The teeth was worn to "knife sharp" points. My suspicion of the cause is the SMF changeover. Two years later, the driver was reporting a "screeching" sound when the clutch was engaged. I assumed that it must be the TOB was getting dry. This is what I found. See pics below.......
