Steven Donald
Got a question. I've seen threads here talking about raising the governor RPM above the factory 3,600rpm and I am guessing most of that data is useful, but thought I would ask here for clarification.
My truck has been gone through by the PO, its a '91 7.3idi with the factory turbo system stolen from a '94. It starts immediately every time, idles great and has GOBS of power compared to my old N/A. turbo spools up to about 10psi at 2,000 rpm and tops at 15psi at 3,000 rpm and falls on it's face. It defuels starting at 3,000 and is done, wont go faster than 3,300rpm with zero load. This isn't a HUGE deal, but i feel like it's losing fuel right where it would be making peak HP and i just want to feel it! haha!
So my specific question. I've read that to change the governor RPM, you have to change the spring on the "torque screw" and that just adjusting that torque screw wont change the rpm, but how could mine be so close to correct and running awesome, but cut off too early? Any reasons anyone know of? If I took the top cover off, you think adjusting that nut to tighten (or loosen) the spring could get me just the extra 300 rpm I am looking for? Also, which way would it be? tighter spring = more RPM or is it looser spring = more RPM?
Thanks in advance for any reply, I appreciate your time!
