Little bit better video this time
94turboidi
Ne So. Dakota
Yeah but you might get better fuel mileage.......because you can start burning those pistons like fuel :)
dyoung14
Is getting worn out
spencer,tn
haha! i use to drive N/A without an egt gauge Pump maxxed all the time, and when i had the heads off the pistons looked perfecr, minus were it ate 2 glowplugs
94turboidi
Ne So. Dakota
I almost turned my pump up while I had it out but I don't have a pyro and I need my truck to be reliable.
DeepRoots
Tug Engineer
Douglas, Georgia
DY, these truck were meant for loads. Diesels are designed for loads.
Running around with fuel/boost maxed out light truck *may* create some disappointment when loaded with a big trailer.
FordGuy100
Silverton, OR
My truck unloaded wont see above 1000* anymore either. Hook a load up behind it and pulling grades if I tried I could get it above 1200*.
dyoung14
Is getting worn out
spencer,tn
I did pull heavy a few times since i had the turbo but never with the wastegate wired the last times it was bleeding off at 13psi, and i didnt have a pyro:eek::sly
