Little bit better video this time
rjjp
Needs to go test
Clare, Mi
No offense David, but it seems to me it's spooling pretty slow, we have the same turbo and mine does 0-10 in the same or less time as yours does 0-5.
rjjp
Needs to go test
Clare, Mi
Just remembered you have a worn IP, that could account for the spool time.
dyoung14
Is getting worn out
spencer,tn
My pump leaks more fuel than it puts into the engine:eek:-cuss and its worn slap out, i got to get another pump
dyoung14
Is getting worn out
spencer,tn
Just remembered i didnt floor it in first till after the boost started to come up because i was making a tun onto another road and it would have spun out
Diesel JD
Gainesville, FL
When you do rebuild that motor you need head studs and a Moose or DPS pump. Still looks like fast spooling to me since I'm used to the 088 and it's lag/low boost.
Rot Box
Northern Utah
Lewiston
That's kind of what I was thinking--My 7.3/088 runs great, but I wish mine was half that responsive :dunno
I'd say you're doing pretty good. It would be cool to see what a hopped up pump would do ;Sweet
dyoung14
Is getting worn out
spencer,tn
I dont know if i will be able to afford a pump, but studs is for sure gonna have to happen
dyoung14
Is getting worn out
spencer,tn
If you had a moose pump it should be better, i have seen a video of deeproots truck his lights off fast
DeepRoots
Tug Engineer
Douglas, Georgia
yeah I got a boost leak now... gonna have to fix that.
more than anything with the moose pump you need to feather the throttle as it overfuels easy.
Thanks for the way better vidieo.... I'm impressed....:sly What would make this really impressive is to have two pressure gauges tied into the pressure port. That would be nice to see that the gauge is proof that you are reading correctly... I tink I recalled that you did test other gauges and they were all the same...:dunno Again... Thanks for a much clearer vidieo....
dyoung14
Is getting worn out
spencer,tn
Yes i have used another gauge, it was one off of a buddys PSD
