Leaving lift pump behind
87crewdually
Southern Nj.
Personally I would of replaced the $27 pump but as long as the mechanical pump is taken out of the fuel system loop, it will be fine. You could get a big block chevy block off plate to remove the pump and cover the hole, but at that point again i'd put the reliable effecient mechanical pump.
