swampdigger
One of my injector lines leaks where it attaches to the injector top. Torquing it down like a SOB didn't help. What about teflon tape or something?
Well...since I just did this today...the way I do it is to push the fitting into the top of the injector and thread the nut on as tight as I can get it by hand. Then I take my 5/8" box wrench and if and only if it threads on smoothly, then torque it down till you can't turn it easily. No need to torque it to death...22 ft-lbs is the Haynes manual torque spec...but I have never used it and really don't know how one would apply a torque wrench to the lines. The other possibility is that the injector threads themselves are stripped...that can cause the kind of leak you are describing. Really, those hard injector lines really don't break unless they rust through or the clamps are busted or missing.
Uhh.... clamps? On the hard lines? We're not talking about the return line clamps, are we?
OOOOH! The clamps that bunch the lines together, with the little rubber pads?
