redneckaggie
rebel w/o a cause
run seafoam because it could be carbon buildup in piston bores but I meant to put try atf first then if that dont work try the seafoam. when my advance was sticking I tried the atf in the filter about five different times and it never worked. Finally quit messing around and pulled the cover and drained diesel, washed with b12, and filled with atf. worked the hell out of throttle linkage once I got the cover back on and then fired it up and let it run about 5-10 sec. shut it down and it has been gravy since.
