Valve Seat Insert Removal
The intake and exhaust valve ports in the cylinder head are equipped with removable valve seat inserts. Remove and replace inserts that are cracked or loose, or that show excessive wear. Use the following procedure to replace valve seat inserts:
A. Use Valve Seat Puller D84L-6084-A or equivalent to remove damaged or loose seats. Position remover collet into insert and rotate collet nut clockwise to expand collet jaws under the lip of the seat insert.
B. Remove insert with Slide Hammer D79P-100-A or equivalent.
NOTE:
Valve seat inserts are available for service. There are four sizes: standard, 0.254, 0.508 and 0.762mm (0.010, 0.020 and 0.030 inch) oversize. Refer to Specifications at the rear of this section.
NOTE:
If an oversize valve seat insert is required, the cylinder head should be sent out to a qualified machine shop for insert counterbore procedures. Counterbore dimensions are shown below. Make sure that the valve guides are clean and within specifications as they will be used for the pilot.
Valve Seat Insert Installation
A. Chill service valve seat insert in dry ice for approximately two hours prior to installation.
WARNING:
DO NOT HANDLE VALVE GUIDES OR DRY ICE. DISPOSE OF DRY ICE IN ACCORDANCE WITH SAFETY AND EPA REGULATIONS.
B. Install the inserts into the head using Valve Seat Replacer T87T-6084-A (exhaust), T86T-6084-A (intake) and a hammer.
Valve Seat Refacing
1. Measure the width of the valve seats and reface the seats if they do not meet the specifications.
2. Measure the runout of the valve seat with a suitable gauge. If valve seat runout exceeds 0.063mm (0.0025 inch), reface the seat.
NOTE:
Reface the valve seat and face at the same time so the finished measurements correspond to specifications.
NOTE:
Valve seat refacing stones used successfully are: Sioux Tools No. K-491, Course cut and K-421, Fine cut.
Remove only enough metal from the seat to clean up the pits and grooves, or to correct the seat runout. After refacing, the seat should measure to specifications. If the refaced seat exceeds the specified width, narrow the seat by removing stock from the top or bottom of the seat. If the seat measures less than this width, widen the seat.
3. Rotate a new or refaced valve in the seat using Prussian Blue or equivalent. Evaluate seat width and valve overhang by the transfer of Blue to the valve face. If the Blue is transferred to the valve face outside of seat width and overhang limits, raise or lower the seat.
4. Check the valve recession using a dial indicator. Valve recession must be 0.84-1.32mm (0.033-0.052 inch). Failure to maintain this dimension may cause the valves to strike the pistons.
NOTE:
Valve recession is the distance the valve sits beneath the surface of the head.
5. Exhaust Valves: Lower the exhaust valve seat by removing metal from the top of the seat with a 30 degree grinding wheel. Raise the valve seat by removing metal from the bottom of the seat with a 60 degree grinding wheel.
6. Intake Valves: Lower the valve seat by removing stock from the top of the seat with a 15 degree grinding wheel. Raise the seat by removing stock from the bottom of the seat with a 45 degree grinding wheel.
