intake hat for IC idea
tractorman86
Buckeye, AZ
so i was walking by a 1048 New Holland balewagon today and a light came on. they run a 361ci industrial FE series Ford bigblock, here is the "hat" that they run for the air cleaner.maybe it could work for an IC system, i think it has a 3" inlet
RedTruck
I'd be concerned about getting rust flakes and paint sucked through the intake.
Paul
69dieselfreak
well that nice
rimrock arizona
My only question is will it hold boost? If it can hold 10-12 psi without leaking then it should work just fine.
hey jake id half to second that one just for the fact that its crimped to gether sheet metal
but in reallity that set up just might work and just gave some new ideas ;Sweet
good find:thumbsup:
tractorman86
Buckeye, AZ
it's not rusted it is painted new holland red thanks kevin i bet if you clean very well and smear some good RTV on the inside of the seams.
69dieselfreak
well that nice
rimrock arizona
the only thing is that id be worried about it crushing under boost it probly wont but id want something more rigid
jake how many of those do you have avalable
tractorman86
Buckeye, AZ
we have several aftermarket companies we get parts for thiese from, i am going to check it out. i can't get away with that particular one though. all it could possibly do is blow past where it seals on the bottom or separate the seam
