Sounds like you have a cut seat in the head. Was this blowing by compression before you changed that injector?. What you need is an injector seat cleaner. Its a metal reamer that makes a slight cut on the cast iron seat in the head. I have two seat cleaners but they are both loaned out at this time. Maybe another member has one to loan. I will call in my loaned reamers if the members are done with them. Are you useing a torque wrench and getting 35 lbs of torque.
