Injector/Glow Plug install under way.
apextrans
What Log Book????
Fallston, MD
I'm pretty slow but all is going well so far. A little tight in places. Not sure how easy it will be to get bolts back where they belong but I'm in no hurry. Here's some pics so far:
apextrans
What Log Book????
Fallston, MD
Couple more before the injectors came out.
Double-S-Diesel
parts seller
derry pa
dont forget to put new o rings ion the breather, also a good time to turn it around for a road draft tube.
apextrans
What Log Book????
Fallston, MD
Wish I'd have know that before. They were in pretty bad shape & I had none on hand.
Here's the last of the pictures I took. Got tired & forgot to take more.
94f450sd
somewhere,ma
you did suck the oil out of the cylinders and crank it over by hand 2 revs before starting it i hope?
apextrans
What Log Book????
Fallston, MD
I sopped up the oil in the injectors cups as best I could, put the injectors in with all the glow plugs out. Put the covers on with no harnesses & bumped the key a few times to be sure it wasn't locked up then cranked for about 5-8 seconds. Oil everywhere when I pulled the covers back off.
