Seems my injection pump has taken a dump.
My 1990 wouldn't even try to start yesterday. It was running fine when I parked it 2 weeks ago. Supposing it was a fuel problem, I cracked a few lines at the injectors and cranked, only a few air bubbles out. I spun the filter off and cranked again, nothing at the filter. So, I replaced the lift pump, restored fuel to the filter, and a good supply at the pump supply line. There was a lot of this
. I checked the FSV and it responds when power is removed and applied. I bled air off the Schrader valve at the filter housing, and have fuel pumping out of the top of the injection pump at the return fitting when I crank the starter. My theory is that the lift pump was failing, starving the injection pump of fuel, resulting in seizure. Unless someone else has an idea, I'm guessing it's the injection pump.
Advice? Anybody have a take off sitting around they would be interested in parting with?
Thanks! Thanks! Thanks!
