Today I finished the head stud replacement issue. Also I changed out all the freeze plugs I had installed and checked with 35 lbs of air. non leaked then... But now I had 4 that showed some leakage. I didn't use any sealant on them but I did this time. Plus I really installed them way better that the second shop did. The really bad part of these plugs is the only way to know how well they are installed is to remove them... Not a good design at all.. Some of the plugs came out really easy and some were really in there. Non of them looked any differant from the easy or hard ones either. I measured the original plugs in my block with around 300,000 miles on it. I made a installer tool and it worked fine.... Tomorrow I run it about 200 miles then Sat. I make a run to Scotsdale with 3 horses. Heres hopeing it runs fine....
Funny thing about this recent work is the motor seems to run smoother than before. Like its been balanced differantly....
. The quality of the mechanics around here is what keeps the new car business thriving.If I were still able to turn a wrench full time, I'd be rich. Most of the yo-yos around here have never cracked a book in their lives and they break more than they fix. I got this engine one state over, not any better.
