I'm new so please don't yell at me!
snicklas
6.0 and Loving It!!
Staff member
Administrator Moderator
Greenfield, Indiana
I wouldn’t get injectors or pump from anywhere but Mel, Russ or Justin (R&D).
The big thing with the injectors from the above 3 is they are all pop tested and matched to I think +-100 psi of each other. The ones from other sources are assembled, boxed and shipped, if new, remans from other than those 3 who knows. But the matching is the important part. The closer they are matched, the smoother the engine will run. Plus this will also give the most power as the engine isn’t “fighting” itself. If they aren’t matched and/or have a horrible pattern you will have a very rough running engine.
Thatoneguy
Boerne, Texas
Was 100psi what you meant to put? Seems like a lot of room for difference....
Sent from my VS980 4G using Tapatalk
Hydro-idi
Lodi, California
Buy a set of D code stanadyne injectors from Russ aka typ4. They are way better than any autoparts injectors, and even better than delphis. I've had them all and can tell you stanadynes are the best.
Jimacho
