ignition switch
flatlander
plays dirty when losing
ft. wayne IN
I finally got a new steering column installed tonight. The old one was worn out and the ignition switch wouldn't start the truck.
Anyway, the new one worked fine, but I couldn't get the key to turn back off. So I forced it and now it's screwed up. It won't turn on or start. It just turns a couple revolutions each way.
Is there anyway to fix just the switch. Or am I looking for another column?
Roland_Jenkins
Señor Member
Nevada
To remove and replace the cylinder
This might work, then again, might not.
Will it turn to the on position?
If so, unhook the batteries. Take the chrome or plastic cover off of the switch so the cylinder is exposed.
Turn to the on position. Stick a straightened paper clip in little pinhole. Pull on the key. Cylinder should pull out.
on edit: FWIW I had one so buggered up I had to drill the cylinder out. Even at that all I had to do was get a new one at NAPA and I was good to go.
Roland_Jenkins
Señor Member
Nevada
Follow the directions I just gave you in my post reply LOL
To install, put the key in the new cylinder, slide'er in and turn to the off posation
ealiaga12
