Hey all, Ive tried searching and cant come up what im looking for. My 94 f350 idi stock turbo truck...should be in my signature too...started not starting. After checking things out, im not getting 1v2 to the fender mounted relay. The Relay works...its just the 12v trigger wire doesnt/isnt getting 12v when the key is turned to start. For now, I have installed some new wires to a push button in the cab...but would prefer to wire it correctly. The wire in question looks to be red with a blue strip. I can follow it accross the radiator to the driver side...but im not sure where it goes from there. I dont see the same wire in the ignition switch under the steering column either. By the way, I have replaced the ignition switch and the key lock cylinder as well. I was having an issue with the key cylinder. I could start the truck and pull out the key and from the on position. Or the key would get all sideways in the ignition. lol. Does any one know where that red/blue wire goes? Shouldnt it go to the ignition switch? or is there another place I can get the 12v trigger power from that would work when turning the key?
Thanks, and hopefully I didnt miss this in my search.
Dave
Dave
