Hi guys, been even busier now that the truck is off the road.
Got an 87 7.3 as a backup and a 94 5.9 as well. Pulled the motor and got the heads off. Couple of things I noticed were the rear most head bolt on passenger side was loose. There was a lot of oil leaking past the exhaust gasket on that side as well. The driver side head gasket was not stuck to the block or head between the rear coolant port and the cylinder. The pre cups are all cracked like normal and the intake and valley pan were sealed up tight. The oil cooler gasket looked to be blown out causing my water to oil miracle. I'm going to use RTV next time.
#6 has a hot spot on it, and is not looking good around the edges along with #8.
#7 was washed clean like it had water inside the cylinder at the time of combustion.
I'm going to pull apart the spare 7.3 and see how it looks and go from there.
Here are some pictures for y'all to dissect.
#8 you can see the worn edge of the piston and the fire ring has deformed
#7 This piston was even worse
It was a bit melted
This is the odd texture in the 4 rear cylinders
The part of gasket that didn't seem to be sealed very well
This is cylinder 7 and it was all nice and shiny compared to the rest
The loose head bolt was next to this one
Anyways, good evening to you all. I'm going to get into the other motor in the morning.
