i need trailer wires
1989f2507.3idi
vernon,nj
sorry to repeat a thread[cant find]
i have the in cab brake box under the dash connector and a t one for out back i took from my 89 f150.
i searched and cant find the ones that connect to the ports out back
MIDNIGHT RIDER
I wouldn't trust any factory trailer wiring harness and you shouldn't either.
Best is to run a dedicated HOT to the brake-box and then out to the trailer-plug, 12AWG minimum, with 10AWG being better.
EMD_DRIVER
Say what?!?!
Beaufort, SC
I already have mine wired direct from the battery and a dedicated 12g wire to the trailer connector. When I found the factory harness, it appears to have a 10g wire for the brake booster. Why wouldn't you use it?
MIDNIGHT RIDER
If it is like any of the rest of Ford wiring, I would just not trust it, until I pulled every inch out in the daylight and inspected it against my standards.
I also dislike having an abundance of "plug and play" connectors in any important system; I like my stuff hard-wired.
Cv axle
