fordf350man
well i just went and picked up my own birthday present, got me a hydrobooster for $28.00 bucks at the junk yard, now im just wondering is there any thing i should do first before installing the hydrobooster?
Please tell us what year truck and what trans it has that this is going in. Are you going to use a 1 5/16 bore master cylinder or reuse the one on your truck now.. I recommend using the larger one. That way you have much more power going into the brake hydraulics. Your more than doubleing the pressure in the brake system. The vacuum brakes ran about 1000 lbs where the hydroboost runs around 2200 lbs. Might want to replace the three rubber brakes hoses too.They fail from the inside out. You usually never see them fail untill the brakes heat up because the fluid can't return to the master cylinder.. The insides collapses on thiem.
the bore on the hydrobooster is 1 5/8, thats what i plan on using, ...
