Your damper has a line on it. The timing plate has a line with a "0", it will be where the larger, shorter of the two tubes is. You may have to clean things up to see the lines. When the marks are aligned, #1 and #4 are at TDC. Cylinders are numbered 1,3,5,7 on pass side starting in front, and 2,4,6,8 on drivers side. Rear on pass side is #7. One quarter turn CW of the damper (15/16 socket) will bring up 2 and 5, another 1/4 turn brings up 7 and 6, another 1/4 and 3 and 8 are at TDC. So in your case 180* rotation from starting point (marks aligned) should bring #7 to TDC. I marked my damper in quarters by wrapping a thin cardboard like cereal box around it and marking overlap, then dividing the distance in four and transferring to the damper. Kind of a PITA and probably not really needed in your case.
