7.3workhorse
Had to rebuild 99.5 7.3. All stock. Didn't get a good, understandable answer to my question else where, so I joined here. My 370K cam had wear ridges on some of the lobes. Bought used cam from salvage yard. They sent me older oil pan and cam with fuel pump lobe, supposed to be out of 2000 F250, apparently and old block with new heads? This is what I posted on other forum.
The first thing I noticed is that some of the non friction surfaces seemed to be polished? Especially between the end bearing surfaces, and closest lobes. On my old cam they are dark gray and rough. I do not have a mic, and I am certainly not a pro with a caliper but I am consistently getting measurements of the lobes on my old cam of 1.828 - 1.831''. And remember I have wear ridges on some of my lobes. On the used cam I bought, I am getting measurements from 1.819 -1.824'' I am sure my measurements leave something to be desired, but the point is that the purchased cam, even though it LOOKS to be in much better shape? The lobes are consistently measuring as much as .009'' smaller? Know I am wondering if this cam had work prior to being installed in a 2000 F250 2000 F250
with old block, and newer heads?
So did I buy a cam that is more worn, even though it has no wear ridges? Ugh!
Can someone tell me what the lobes on a good cam should measure? From measuring my old cam, I'm guessing 1.830''
I am only measuring the max diameter of the lobe, common sense tells me that if the lobe is .009 smaller, then modifications would have to be made to something else to get enough valve lift? I assume longer push rods? I am not into mods?
It was suggested that it probably was reground and would be OK to use. Trying not to make my book any longer, the explanations of how grinding the back side/ small side of the lobe gives more lift were given.
My final question was - even though I worked a late long sat. night, I am still up googling what I am missing here, I had finally decided that it must be the valve action of the hydraulic lifter taking up the slack when not under pressure, then due to the smaller back side of the lobe the lifter locks into a solid state sooner thus starting the lift earlier??????? But if due to the smaller back side of the lobe the lifter valve locks solid later this wouldn't work??? Well at this point I am so tired that I'm not sure I even understand what I am saying myself? Goodnight!
So can somebody here explain to me how grinding down the small side of a cam lobe where the valve would be fully closed/ seated is going to result in more valve lift??? Hopefully in english! Sorry about the length
