I did the HG's on my truck last summer. Big job but very rewarding. A list of comments to confirm / reiterate what may have already been stated.
1. Do head studs. To save money I used Xotic performance studs (way less $ than ARP). Very happy with them.
2. Make sure you rebuild the oil cooler.
https://classicdieseldesigns.com/pr...A6Y-WQQJjK2pTH43q7dZgh_zc_NrgyNYZRRKyA4Zg2yDV
3. For head surfaces, I used 3M Roloc discs to remove the old HG residue. This disc is aggressive on the residue but won't be too h_ard on the cast surfaces. (site does not like 'hard' followed by 'on' for some reason)
4. If you need a good gasket stripper search for Loctite Chisel SF 790 spray; this is the good stuff, like paint stripper in the old days.
5. Do the head cooling mod - basically knock out the freeze plugs
https://www.oilburners.net/threads/7-3-cooling-mod.81986/
6. Absolutely change the oil pan and rear / front main seals.
7. Consider new engine mounts; probably due
8.The only connection I missed when pulling the engine was the fuel return line... Out of sight out of mind...
