steelholder
Going back to the PS, is there a way to remove it without having to pull the pulley? First time doing it and def didn't want to get a kit for thatYes remove the hood. Why are you disconnecting the power steering line(s)? I just pull the whole bracket off of the engine and wire it out of the way. Your AI search on engine pulling mentioned that in the section talking about the support systems in step #4. It did say to use a bungee cord to the frame, but it's basically the same thing. I like to tie it up higher than the frame. If it's against the frame, it's down low and out of sight. That means that it's easier to set the engine down on top of it when you're putting the engine back in.
I also don't know about the bottle jack against the lip of the transmission pan. That seems like a lot of weight on a small area. It looks like there's a good chance of damage. I always use a transmission jack or a floor jack if you don't have a transmission jack. I'll put at block of wood on top of the jack and put that against the pan. That way the weight is spread out over a MUCH larger area. I also don't mean one of those cheap little floor jacks with a head that's about 1.5" across. Use a floor jack with a head that's 5" or 6" across. That will support the wood block better. There will probably be some wiggling as you're putting the engine back in. A small surface area holding up the transmission will be a lot less stable than a larger one.
