Reggie f250
They are standard replacement head bolts. Similar to the original bolts
I think this is the perfect kit for this project, what do you guys think? I know it has more than I need like the valve cover gaskets that I already did + other parts but I am hearing its a great brand - The guy from this company I just spoke with said I can go with stock head bolts if I am not running a turbo, thoughts?They are standard replacement head bolts. Similar to the original bolts
Any opinions on Viton front and rear seals? I have heard to only go with the national brand. I also don't know if them having a sleeve means anything. Can i just take the sleeve off if I dont need it? Not really sure what the right question to ask regarding the sleeve is. Never done this job before but I notice some have a sleeve and others dont.He's right. There's no need for head studs if you're not running a turbo. Even the engines with the optional turbo that Ford offered had head bolts. The general rule of thumb is that a 7.3 can take 15 PSI of boost before you need to use studs. People have had more than that, but it's a good safe place. Even if you decide to use a turbo in the future, head studs aren't a requirement if you're running low boost. I see no reason to not use the bolts in your case.
As far as the gasket kit goes, I think that would be a good choice. You can hang onto the unused gaskets for future use if you need them.
OK so even if i don't end up using one its ok to order one with a sleeve? Sorry I have no idea what this will look like or need till I get a chance to get eyes on it.A "sleeve" usually means a repair sleeve. Those are used over the back of the crankshaft and the harmonic balancer if there's a groove worn into them. It gives you a fresh surface for your seal to seal against. The grooves occur because one or the balancer or crankshaft (whichever we're talking about) has spun against the seal for a long time.
There is a type of rear main seal that uses a plastic install sleeve for you to install it. After the seal is installed, you just pull the sleeve out and throw it away.
you leave the radiator and fan attached?Although a lot of people do, I never remove the core support or the other things attached to it.
No. I remove those. I meant things like the grille, head lights, etc. The engine can be changed out with the radiator in like Nero said, but I feel like there's too good of a chance to damage it that way so I always pull it out.you leave the radiator and fan attached?
Could you elaborate more on the part in bold. I think I can picture about half of what youre describing, thanks.No. I remove those. I meant things like the grille, head lights, etc. The engine can be changed out with the radiator in like Nero said, but I feel like there's too good of a chance to damage it that way so I always pull it out.
A few more things. Be sure that change the front seal in your transmission before putting the engine back in. Otherwise it will most likely leak. When pulling and going back in with the engine, go slowly and keep looking around to make sure that you didn't forget to unhook something or that nothing is being pinched when going back in. Keep a close watch on the torque convertor while going back in with the engine. Make sure that the studs are lined up with the holes in the flexplate. As the engine gets closer, I like to keep wiggling the studs to make sure that they have play. There will still be play in the convertor studs after the engine and transmission are bolted back together. That's what the nuts are for. If you get to a point where the two aren't together and you can't wiggle the studs, STOP! You'll have to pull the engine part way back out and make finish seating the convertor. A trick I like to do is to put the convertor drain and the stud next to it at the bottom. Then I rotate the engine until one of the stud hole sin the flexplate is also at the bottom. That makes it easier to line up the flexplate and the convertor.
Thanks I should start pulling it this weekend, wish me luck yallAs you are getting the engine and transmission closer together, you first have to make sure that the torque convertor studs and the holes in the flexplate are lined up. Then, as the studs start going into and through the holes, you should be able to move a studs a little bit with your finger. As long as you can do that, the torque convertor isn't in a bind. If it is and you try to force the engine and transmission together, transmission damage will occur. As long as you can move a stud with your finger, keep going, if you can't stop before damage happens. When the engine and transmission are bolted together tightly, you'll still be able to move a stud with your finger. The nuts are what holds the torque convertor tightly to the flexplate and takes away the movement.
