tuckerd1
WAR DAMN EAGLE!
sle2115 said:I haven't had any problems with heat as I put a long (4" or so) nipple on it and moved everything outside the exhaust. The only problem I am having is the brass nipple will break from vibration. I am going to use some Russell ProFlex braided hose and mount a 1/8" pipe distribution block elsewhere and install the two senders, should eliminate vibration damage.
Yeah, I tried using brass fitting to initially install this and broke the elbow off in the block. Got it out and then went to galvanized steel fittings then. Should last.
But the flex braided hose sounds like a good fix!
