ok, i'm ready to install an electric pump. i have two questions . 1. which circuit do i need to tie into for power? 2. should i be installing an inline filter before the pump? or will the pump have to work to hard pulling fuel.
Does Fram make a cartridge for this filter head that is suitable for diesel fuel. The only one that I have found so far is for gasoline.Yes, you should use a filter before the pump. A Fram HPG1 filter
sle2115 said:I have mine installed on the driver side of the engine where there is a 1/8 inch pipe port. I have a T and my electrical oil pressure sender located there as well.
tuckerd1 said:I installed the OPSS in this location. Do you have any problems with heat in this location? It sure is close to the manifold downpipe. I had to use an elbow and a 2" nipple to get it away from the manifold downpipe. It was so close, I had to unbolt the downpipes from manifold to get the elbow installed. I strapped the nipple to bellhousing bolt to prevent vibration damage.
