HELP
That thread has been viewed 63 times. I am going to guess everyone agrees with what has been said already by the one guy that replied. Believe me, if someone disagrees with someone's diagnosis, they will post and give their opinion.
The only other reasons for coolant nd oil to mix is the oil is getting into the coolant because the bolts in the water pump were not sealed. Only yht top and bottom two bolts reach into the oil side of the timing cover where oil will leak past the threads but not like you describe. That amount of oil in the coolant is from the oil cooler.
