Help please
Salvatore vaci
Illinois
I have a 02 7.3 with a 7.5 inch lift running 37s with slight rub on full lock it’s rubbing on back end of wheel well towards cab more to the inside frame is there a way to cut that out ? Or should I go higher anybody have these issues lookin for advice thanks
clint bartels
South East, WI
My advice would be to change wheel offset or tire size. I can"t say as I have ever seen good things happen from cutting to make them fit.
Salvatore vaci
Illinois
I was thinking riding the thread down nd then selling the rims changing offset it’s a bit much at -76
Sidewinded_idi
Yucaipa ca
It’s hitting your radius arms If it’s 2wd. Impossible to cut them. Only thing you can do is more offset to your wheels or spacers
Salvatore vaci
Illinois
